Installing turbo timer
4G63GSX97
Sep 2, 2009
Bristol, Connecticut
Ok so this seems to be my only option...I can't seem to get my timer to work through my ignition..so I want to find the ground wire to my ECM...can anyone help me.? Or give me another alternative..maybe picture step by step installing turbo timer? I kno I can probably go through the ECM but can't find the ground wire
i used no harness and installed my old school hks black edition in literally 20 min. Just get a ecu pin out look up what needs to go were and i have my wire to keep car running tapped onto ignition 1 on the steering column.
I tried the harness. It is the apexi small grey one. The harness.did not work. Put it to my e brake and to.the harness then grounded it.under the dash. It stays on when I have the key turned to.accessory but when.I shut it.off ot shuts off also. Can't get it to stay on and.keep.the car running. Might have to run it the old school way. So I run.it to any pin in my ecu. And to the e brake and to ignition wire 1?
E brake.is on.and it is grounded. When.I turn the key off. The turbo timer also shuts off. Not sure why
The plug and play harness definitely seems like the way to go for you....it's so much easier than trying to pin out or splice wires and all that hassle
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
