Installing tranny with Xfer case still attached
ImportModder
240
May 30, 2002
Washington, Wisconsin, Michigan
First off, is it possible to install the tranny back in the car with the transfer case bolted to it? The reason I ask is that the center output shaft got stuck in the transfer case and came out with it when I dropped the xfer case. I had to pull the transmission out in order for the output shaft to completely come out. The ball holding the shaft in place was missing.
I tried to get the shaft out of the xfer case, but it is stuck in place. So, in a last ditch effort, I was hoping maybe someone would know if you can put the tranny back into the car with the xfer case bolted up. I just want to get my car back on the road.
No. You won't be able to get around the flywheel with the x-fer case bolted up. But you've got other issues. If the output shaft is stuck then it's FUBAR'd. I wouldn't attempt to drive on it. The splines may go pop and strand you on your next trip.
Trust me, I have TWO messed up output shafts on my workbench!
Rick - '91 GSX :dsm:
Thanks for your reply. Yeah, I found out that the flywheel gets in the way. I ended up putting in the transfer case with output shaft attached and the oil pan on at the same time. That's something I don't want to do ever again. The car is back on the road and doing fine. Small oil leak considering I couldn't reach two of the oil pan bolts since the transfer case is in the way.
I have another transmission and transfer case on route that will be rebuilt and replace the one in the car since I can't separate the output shaft from the transfer case. I realized I'd have to replace this sometime soon in the future, but it needed to be running before the end of the month.
