GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
I just finished a WB02 install today. as well as a Hallman MBC. I started the car just fine, did the whole calibration of the innovate WB (free air first). and within the first few minutes of idle, i get a CEL. I drive around a bit to set the MBC to 14psi (have boost gauge, prosport, seems accurate enough, gets 20 in at idle, and 10-11 psi with the BCS hooked up, no restrictor).
So after I finish dialing my setup in, I check the CEL codes with a volt meter. I was expecting a o2 code, but there is only one code. 31, knock sensor. What could this point to? I dont think that sensor should be going out any time soon... (laser has 25k original miles and is really clean, but still a 92...) I dont have LINK yet, and I dont want to pay for a pocket logger till I get link.
My AFR'sare off, ~15 at idle, (otherwise normal, rich under decel, around 12-13 on accel)
I was really hoping this was gonna be plug and play, not plug and diagnose... aaaahhhhhhhh
thanks
thanks
