Installed plugs/wires....
91boost
221
Sep 17, 2004
Palm City, Florida
Well I just put the Accel wires and NGK BPR6ES plugs in last night. Original wires/plugs had over 78k on them. Let me tell you, BIG DIFFERENCE! I wish I would have done it sooner.
Feedback? The Accel wires were high quality as usual, but seemed to be a bit too long. I can live with it though. All the stock wire separators crumbled when I tried to remove them- probably deteriorated over time from the heat of the valve cover. What did you guys do about this?
OEM plugs were easy to remove, and I also put anti-seize on the new ones to ensure that they never do.
I bought a new PCV valve too. Didnt install it yet. It looks like the old one just unscrews from the v-cover....is it really that easy? It looks like one of those things that could ruin an afternoon if your not careful removing/installing it.
:thumb:
I'm not a big fan of the Accel wires. I put a new set on my Talon and two of the wires were defective. As I had to put two of the OEM ones back on to solve the miss I developed with the Accel wires.
I will stick with Magnecor in the future. Glad to see that you got a good set at least. :thumb:
Just get some better quality wire separators, or don't use them at all.
Yes, the PCV valve is really that easy to install. it's just a little ball and spring check valve. Make SURE you pay attention to the torque specs on it because it's very bad news if you crack your valve cover and it's ridiculously easy to do. Did you get the Accel Thundersport wires? Those will be great. Can't say much about the Magnecores since they're the worst wire you can get.
I used the separators that came with the Accel's(yes, thundersports). They are ok, but dont quite grip them well enough for my taste. I'm gonna buy some better ones and re-run them. When you were installing yours, did the large separator break(the one that guides them throught the plug cover)?
Well, I know it(PCV) is an easy thing to install, but I was speaking of the ease of cross-threading/cracking the VC issue(as you did too). I have never seen one that is screwed in like that(let alone have one at all). I have plenty of mechanical experience- it just looked tricky so I saved it to do when it's daylight out. :)
Magnecors? Well, I had them on my MR2 and they weren't that great. I also had them on my Jeep, and they worked wonders on it. I would not use them on my GS-T though. There are plenty of other wires I would use instead.
I don't have seperators on my Superconductors. I just manage the mess by having the boots rotated a certain way, and the spark plug cover takes care of the rest. Plus the wire boots have a 90-degree "sleeve" that the wires fit into, so it keeps things pretty nice looking.
I don't see cross-threading being an issue, even with the aluminum being as soft as it is. If the valve screws in easy, you're good.
You are spreading mis-information. Low resistance wires is a ploy to sell cheaply made wires. Read up on capacitive discharge ignitions before you post information about wires. There is a reason the OEM wires have over 3000 ohms resistance. In most cases the OEM wire will outperform all of these "low resistance wires".
Apparently so is the thread I linked to...right. This isn't the thread to argue this anyway, so hopefully this will be the last thing said about this. I'll ignore any further rebuttals.
Cheap wires like the MSD Superconductors? Please.
Read up on ignition systems. Better yet, here's an article on how electricity works. To get a spark, you need a couple things: voltage and amperage (capacitive discharge or not). The more resistance you introduce in one end of an electrical system, the less output you'll get on the other side. V = IR. Do the math.
Give me one case, please. Consider that the factory wires are "good enough" for a stock application, and were a marriage between cost and performance. A lot of us are not running stock cars, you know. I'd still take 3000ohms/foot than 6000. If you figured out Ohm's Law yet, you'd see thet you're getting half the voltage given the stock current (in amps) than you'd get if you were using the stock wires.
Sorry you paid so much for your crappy wires. They probably work "good enough" though.
Before you put that PVC valve in you need to make sure it seals under boost pressure. Apply air to the barbed end that normally runs to the manifold and make sure nothing comes out.
Most of the cars that use this PCV valve are NA and don't have the requirement that it seal on boost so almost every aftermarket valve I've seen leaks.
Steve
91boost said:
I, and plenty of others, disagree with that.
That's fine. I may not be able to convince you but it's other people that want to know the truth that I care about. The OEM wires will outperform any of the low resistance wires. If I could remember the link I would send it to you but on a Honda forum, they tested all these "low resistance" wires on an integra an a dyno and they all lost hp compared to the OEM wires. Can't find it but I did find this: http://www.vtec.net/articles/view-article?article_id=8680.
There's more to secondary wires than fancy silicone colors & low resistance cores. You can't measure the performance in Ohms. The real measurement is on the dyno. There is a reason that most import drag cars use Magnecors. I'm not going to continue argue and ruin this thread so you buy the low resistance wires and I won't. ;)
Agreed. :thumb:
I actually would have just bought OEM, but I can get 2 sets of Accel Thundersports for the same price.
