spark plugs + wires installed = failure
DsmKid98GST
133
3
Aug 25, 2005
Winter Springs, Florida
I installed NGK Bpr6ekn spark plugs + msd wires today and the outcome when i turned the car on was a failure. Everything went in fine sparkplugs aren't cross threaded and the wires are snapped in right in their proper sockets. When I go to crank the car over it takes longer than normal and then runs terrible. I didn't give it any gas because i knew something was wrong but it attempts to backfire like there is no spark going to the engine.
The only thing that can come to my mind is that they aren't gaped correctly. When i went to gap them the area to gap wasn't the same as the Autolite that were previously in the car.
I know a few of you have the bpr6ekn plugs any helpful tips onto why the car is running bad after the installation?
the gap is suppose to be at .028-.031 I didnt gap them because I didn't know how. They were different setup than i was use to seeing. Instead of 1 prong above the gaper there were 2 prongs on each side of the gapper. How do i reset my computer i can give that a try?
Make sure you ran the the correct spark plug wire to the right coil. :thumb:
i know you said you did this already, but make sure. because that sounds like whats the problem
- The order from front to back on the coil 4 1 2 3.
- The cylinders are from the drivers side (timing belt side) 1 2 3 4 passenger side
Those plugs are preset gap. You cant gap those anyway. You reset the computer by disconnecting the battery. But you wont need to since you had youre firing order wrong.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
