Need wires & plugs
Status
Not open for further replies.
dubslpr
Mar 20, 2005
SF, South Dakota
The laser is only firing 3 cylinders and sounds like a lawn mower. I'd like to get this taken care of this morning but don't have the slightest clue on what the best wires & spark plugs are for the money. I don't like to put money into this car so what's the best bang for the buck??? :laser:
I would put for plus bpr7es and magnacore wires. Good luck on getting that fixed it all goes well.
what part number for the accel plug wires? aren't the 8es or 9es a lil better???
On a stock car like yours, run the 6es. You aren't quite ready for the 7s yet. As far as the best bang for the bucks, you could run stock NGK wires or if you wanted a little better wire, opt for the Accells. An 8mm is all you need, hell, even a 7mm will do fine. I noticed no difference in my NGKs then my 8.5mm Magnecores.
I run Magnacores with BPR7ESs, though I would rather run Taylors and 8es since the car flows quite a bit of air. My bros car runs well with NGK 7mm blue wires and BPR7ES plugs.
I got the BPR7es and some Duralast 7mm wires all for less than $40. :cool: :thumb: :laser:
if your stock...that's the way to go.. Autozone warranty's their wires for life if you get them there. they don't have the BPR7ES or the 6ES... stock stay with 6ES... plan on going bigger get 7ES... You can order tham at a number of places or get them from your dealer.
Personally, I'm running 10mm Magnecores with BPR7ES. :dsm:
Ok, this question has been asked a billion times.
People will always have different views. You have some options, now it is your turn to chose.
And bolt on tech???? I don't think so. Thread moved and closed.
Status
