wally01
- 0
- Aug 22, 2009
Denmark,
Wisconsin
i just had a crank walk on my 97 eclipse spyder gst. just got a complete rebuild including crankshaft, stage 3 clutch, 12lb flywheel, pistong, rings, oil pump, new turbo, the whole works. when i got my car back it idled at 150rpm and when i came up to stop signs, between down shifts it would die. brought it back to the shop n they adjusted the ecu. car ran fine. after 500 miles i got the oil changed, car ran fine. i let another 500 miles go by and i decided to add the new air intake. now my car idles fine, and when i drive slow n not give much gas so only a few boost let out car is fine, but when i am a little heavier on the gas and more boost goes, between shifts the rpms drop n it will die... is the ecu not adjusting? it only happens after bigger boost... any help? thanx
