inspection plz
emeracing
63
Sep 3, 2014
oakhurst, California
can you guys look at the pics and tell me if the pistons are ok because the pistons did slap the valves when the timing belt broke. please.
The sections on the piston where the valves hit will create a hot spot. Personally I would not run it but I have seen people sand them smooth to run it as a stock block.
Looks like you also have bent valves, either buy a stock long block to drop it in or begin the rebuilding process.
