injectors swaps for a 420a
Turbizmo
430
Jul 3, 2005
Salinas, California
i was wondering what kind of other injectors i can use other than the stock ones and 1g eclipses. I would rather have some that are just plug and go/play. I heard that i can use (1996+?) Mustangs. but are they the gt models of none gt? I just want to know which ones are good so i can go check out cars in pick n pull :sosad:
The bigger question is how are you going to be controling them? Looking at your profile you are using a FMU, so, how the hell are you running 18psi..?
i was hitting about 15 with a fmu... just not wise haha,
OP
you need a better way to control the injectors like shadow said your injectors should be fine with an fmu till 10lbs anything after that like i said its not wise the internals/fuel isnt able to handle it
OP
Oh it says 18 psi my bad:( i am boosting 8 psi not 18 and i have a V SFMU I dont want 450cc from a 1st gen i juat wanted to know what other injectors i can use on my 420a that around 300cc to 400cc some that will be high inpedence well kinda plug n play like i said
Just make sure the injectors are top feed and high impedence.
Well i went to the pick and pull and i saw a dodge avenger 2.5 v6. and i saw that it have the same clip as the 420a model as well as the 3000gt v6 model. i was just wondering because i cant find info about these injectors if there high inpedence or low inpedence injectors and what cc s' are does injectors and will they work??????
have you tried to fit the 1996 gt injectors in your fuel rail yet i just want to see if you are sure that they fit in our cars.
hey turbizmo if you have injectors from a mustang and they fit i will buy the other four from ya. if ya have all 8.
Vehicle Injector Types Factory Flow Rating Notes
1990-'93 Geo Storm GSi Peak and Hold 222cc
1990-'93 Geo Storm 2+2 & Stylus S Saturated 222cc
1990-'93 Isuzu Impulse & Stylus XS Peak and Hold 222cc
1991-'92 Isuzu Impulse RS AWD Peak and Hold 322cc
1988-'91 Civic Si/CRX Si Peak and Hold 240cc
1992-'95 Civic Saturated 240cc
1996-'00 Civic dx cx and lx Saturated 190cc
1996-'00 Civic ex/si Saturated 240cc
1990-'91 Integra RS/LS/GS Peak and Hold 240cc
1992-'00 Integra LS/GS Saturated 240cc
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
2003-'07 Honda Accord 3.0 liter V6 Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 280cc
1991-up Sentra SE-R/200SX SE-R Saturated 265cc
2002-up Subaru WRX Peak and Hold 380cc Baby Blue
2002-up Subaru WRX STI Peak and Hold 500cc Pink
1991-up MR2 Turbo Peak and Hold 440cc
1987-'92 Supra Turbo Peak and Hold 440cc
1993-up Supra non-Turbo Saturated 315cc
1993-up Supra Twin-Turbo Peak and Hold 550cc
2000-up Celica GT-S Saturated 310cc
1990-up Miata 1.6-liter Saturated 215cc
1993-up Miata 1.8-liter Saturated 240cc
1984-85 RX-7 195500-0900 Peak and Hold 680cc Orange Top
1986-87 RX-7 195500-1350 Peak and Hold 460cc Red Top
1986-87 RX-7 195500-1370 Peak and Hold 550cc Tan Top
1988 RX-7 195500-1350 Saturated 460cc Purple Top
1988 RX-7 195500-1370 Saturated 550cc Purple Top
1989-91 RX-7 195500-2010 Saturated 460cc Red Top
1989-91 RX-7 195500-2020 Saturated 550cc Purple Top
1993-up RX-7 Twin-Turbo Saturated Primary 550cc Secondary 850cc
1990-'96 300ZX Twin-Turbo Saturated 370cc
1991-up 3000GT/Dodge Stealth non-turbo Saturated 210cc
1991-up 3000GT VR-4/ Dodge Stealth R/T TT Peak and Hold 360cc
1989-up Eclipse/Laser/Talon Turbo/non-turbo Peak and Hold 450cc Blue Top(95+ Black top)
390cc Tan top
240cc Orange/pink Top
210cc Light Tan Top
Mitsubishi EVO Peak and Hold 510cc Yellow Top (1-3)
560cc Red top (4+)
1986-89 Ford turboCoupe Peak and Hold 35lb/hr Brown Top
30lb/hr Green Top
