420A turbo injectors on 420a
Status
Not open for further replies.
RadTalon95
Sep 24, 2003
Billings, Montana
i have a spare set of stock 1g turbo injectors and a 1g fuel rail, can i put these on my 1995 non-turbo talon 420a motor,and have it bolt on,and run right,and should i get the walbro 255lph fuel pump to help support it?
if your stock like your profile says then you will not need to put those on. they will do nothing but make you run rich. you wont get any power the fuel rail will not bolt up.
it probably wont fit, different engines. Injectors might fit but the impedance of the turbo injectors are low impedance and dont even bother putting the 255lph in because that will require an afpr. You should only think about these mods when you are really getting some serious air flow through the head.
dude your going to run rich as hell.... your fuel is going to be gone before you leave the gas station.... haaha not realy.... but it'll be rich
i put in 335 cc injectors on my 99 eclipse with a hahn stage 2 and is is fine. 255 may be too small to the stock 190 cc's
4G63 injectors require a resistor pack to run on a 420A. Like Chris said, the fuel rail won't bolt up, and there are no advantages to doing this given your car's current level of modification.
The answer to this question could've been found through searching...
Status
