injectors and maft
Fl0p
Mar 11, 2010
Bloomington, Minnesota
i want to run a maf blow threw set up with 560 evo injectors and walbro190.
wescion pistons
1g rods
mild port polish
bc 272 cams
bc springs
bc retainers
evo3 16g
mbc(at stock boost level)
boost gauge
down pipe back 2.5" exhaust
with all this and a maf translator and some 560's and walbro190 i was hoping to run 22psi at max to keep the knock down..
let me know what you think thanks =)
Whats wrong with your stock MAF? I would use that till you outflow the MAF, you sure wont with a 16G
The only reason I see why is if you want to vent your BOV.
i would prefer a gm maf because it has no resrictions like ours do..
and i do have a logger and im on the look out for a wideband
