Injector Wire Voltage
FunWheelDrive69
Nov 26, 2008
Calgary,
I'm having a problem with a dead 1# cylinder, the cylinder was cutting in and out, and now it just doesn't run at all. I've narrowed it down to my injectors harness, On every other harness except for harness #1 I get 12v's on both sides of the connectors, when having my negative of my meter grounded. When I did cylinder number one, the connector that faces towards the passenger side of the car (I don't know if thats supposed to be positive or negitive) only gave me 9.3v while the other side gave me 12v.
Would a break in a wire cause low voltage? ECU? Resistor pack? Car is a 1992 Tsi.
I'm having the same type of problem except I'm getting 12v on both sides on all the connectors when the meter is grounded please help us
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
