injector voltage
schumy
79
Sep 5, 2011
westfield, Massachusetts
I have a 95 gsx and it will start up fine closed loop 02 will cycle and I'm around 14.7 but as the engine runs the ratio goes leaner then maxes at 19.5 starts to stutter and I have to keep it running by the gas pedal ...does battery voltage at around 11.0 give injectors a problem?? I have replaced the alternator and battery ..and I have heard the the dsm charging system is not that good??
If you have only 11 volts your charging system still isn't working.... .
I'd be guessing in the dark with out more info of what's going on... .
But these are some things that come to mind off hand
Incorrect deadtimes per voltage set in the ECU(running after maket injectors), a fueling problem,AW/b o2 sensor going out with narrow band simulation enabled, Or some kind of incorrect global fuel setting... all I see in your profile is a SAFC keep in mind when pulling fuel out the car is reducing the Airflow(via a Safc) to the ECU is going to affect your load seen by the ecu an affect timing as well... .
More info will get you more accurate help...
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
