CTS wire voltage?
beamer1341
Mar 19, 2011
Mt. Dora, Florida
So i was playing with my multi meter today and found I only have .5v to the CTS when haynes says it should be ~4.5v
Any Suggestions to solve this?
Thanks Branden
I checked the sensor its has resitance within range but according to my haynes the harness/vehicle side should have app 4.5 volts with key on. I only have .5 but I've never really like haynes manuals but it came with the car so...
Are you testing the harness itself? One wire should be the reference voltage, and the other that actually gets back to the ECU to determine coolant temperature. I would say you are testing the return wire, not the reference. The manual probaly says you will have a 5 volt reference.
Actually the green-black wire is an internal ECU ground while the yellow-green is the sense wire which has an internal pullup to 5v. So if not connected the harness will read 5v on the sense wire. But when connected the resistance of the ECT sensor acts as a voltage divider so the voltage across it will be between 0 - 5v depending on its resistance (which is inversely proportional to its temperature).
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
