CTS problem?
Beezle
105
Dec 10, 2004
Long Island, New York
I have a 91 tsi awd with a cyclone motor in it. The car runs good except for a couple little problems. The car idle's funny sometimes (seems like only when it's been running for a while) and also stalls once in a while. The car will also hit fuel cut (what it feels like) in 3rd gear and higher if I step on it at a low rpm. It will pull in 3rd gear and up if I redline 2nd and slam 3rd. The last problem is the car takes a couple cranks to start sometimes (especially when it's cold).
I changed plugs, wires, and fuel filter. I do get a cel after the car runs for a little bit. I went to my friends shop and he hooked it up on the computer and it's throwing 21 Coolant temp sensor out of range and 24 speed sensor (my speedo cable is broke).
So today I went to a local parts store and picked up a coolant temp sensor and put it in the car. I'm still getting the code and after it's running for a while the idle start to surge and will stall sometimes. This is how the sensor is wired up. Is that right?
Also, the sensor (for the ac I believe) isn't wired up right. That wouldn't cause a problem will it? Pic for reference. Don't know if you can tell but the left wire is cut off.
Any help is appreciated. Thanks
Hey sorry to bump the thread but in the 2nd picture you can see the Coolant temperature sending unit (in front / on top) of it is the CTS for the ECU. Anyway I was wondering how do you get that rubber cap off of it? Attached is a better picture of what I mean.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
