CTS problem
osswalam
32
Mar 2, 2004
Hamilton, Ohio
I keep getting a check engine light because of my coolant temp sensor. I hooked up a scan tool and it said it was at like -50 degrees so I played with the connectors, which are just female electrical connectors (my wiring harness was mess when i got the car). After switching them and doing some wiggling I got it to read 122 degrees (car was a little warm), so I cleared the code and went on, it drove fine for a while but now the code is back and I'm not sure what to do. Should I suspect the harness/computer or should I replace the CTS. I'm low on funds so the $30 - $40 CTS is not something I want to buy unless it is the problem. Do these things go bad often? Any help would be appreciated because my car runs like crap when the CTS is not working properly. Thanks.
Adam
Moved to Problem Diagnosis.
Sounds like you either need to replace the sensor or you have a wiring issue.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
