injector trouble
reign 1
Dec 23, 2010
milton, Delaware
my #3 injector is stuck. as soon as i turn the key it turns on like a fire hose of gas.
i changed the injector and it still does the same thing. please help.
You have an injector trigger wire shorted to ground, or a problem with the ecu injector driver holding the injector open i it still does it with a new one.
i think i have the same problem injector is not pulsing though or stays on not sure sounds like a wrx but will start up some times and run fine till i shut it off any ideas car is my daily driver would be great too here if you fixed this problem if you can you should give me a call 509-954-9449 WA state number thanks man
