injector sizes
sadc
274
Feb 17, 2008
Kapolei, Hawaii
i have a 2g RS-T and i was wondering will any type of injector fit my car. Like if I get one from a honda? Can I just swap out the O rings and im good to go? Also Which car comes with the 450cc injectors? is it the first gen eclipse? thanks:D
The 420a motor comes with stock 195cc injectors. If you want to run bigger you need to find a way to tune them. IE: SFMU, MSNS ect.... You cant just swap out your injectors for DSM 450's. Your injectors are high impedance and the 450's are low impedance. You need to use a resistor pack form a turbo dsm aswell. Unless you run MSNS then you can run whatever injector you want. I suggest you check out 2GNT.com - home and look in the tech section. You will find the answers to your questions.
1g Turbo (5 Sp.) = 450cc
1g Turbo (Auto) = 390cc
2g Turbo (all) = 450cc
All of these are low impedance. To run them you're going to need an injector resistor pack.
