Injector Selection help
94'TSI'AWD
189
May 2, 2009
central point, Oregon
hello I am looking for a good REPUTABLE brand to order a set of injectors from. Now i want ONLY "Bolt On" injectors, I have heard horror stories of people purchasing injectors and having to drill out fuel rails and such.....I don't want to do that. What about FIC? and good/negative reviews?
Mitsubishi Fuelinjectorclinic
What do they mean by "Low-Z"?????????? and they also have strange size injectors, are the 650cc or the 750cc injectors supported by dsmlink? Please advise with input and experience. Thanks :rocks:
How old is that book? There are many different options for 18g's theses days for instance fps sl2 which they were showing 400hp with them. Yes I know that old saying I have been around dsm's for over 12 years alot has changed since those days!
The book was published in 2009. Here is a link to it.
Yes I agree with you, there are arguments for both sides, but that's the same for everything. There is no perfect turbo or setup that works for everyone. Some people swear by 18G's. Others say they are a waste. Take your pick. For me, I'm looking at a TDO6 20G or 20G hybrid, mainly because I'm FWD and want to be competitive from a stop, not just from a roll.
But anyways.... enough about turbos, back to the fuel injector discussion
You should probably buy bigger injectors since you have DSMLink. It will give you room to grow in case you ever want to upgrade to a bigger turbo.
I've had fic 650's, 850's and then 1250's all tuned with dsmlink. All ran like stock after tuning, however I did waste money by slowly upgrading. Buy once and get it over with-get the biggest injector you think you'll ever need now and save a bunch of cash in the long run.
  • Wanted 6 bolt NT water pipe
    • chrisman287
