injector seals
chehsgsx
141
May 15, 2007
monroe, New Jersey
Hey just wondering if you can use the Viton seals from fic on stock injectors.
It say on the website "These are not seal kits for OEM Injectors!" but idk why, and is there any better option then the oem seals for stock injectors??
Thanks
I just bought some mitsubishi injector seals and they were revised. They were a soft rubber not the hard rubber they were before I think I paid something like $6.00+/- for a set.
Ohh i see, ok so should i go with Mitsubishi seals or fic seals???
Which injectors are you using. If then are ND/Bosch/Lucas style use the OEM insulators. If they are FIC modified Rochester ones use the FIC insulators.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
