Injector install or no
98GSXboosted
166
3
Oct 3, 2005
oxford, Massachusetts
I installed the EVOIII and I am currently running stock injectors. I bought 680's and I am wondering if i should install them or not. I have an S-AFCII but i have no logger or EGT to tune it. So my options are running stock injectors w/ evoIII at 9PSI... or the 680's w/ no tune for a week or 2 until I can borrow someones logger.
Sure you can run it, but don't set your boost more than 14-15psi and take it easy until you have all of your supporting mods in place.
Hope that helps,
Andy
As long as you keep boost low or better yet, don't get into the boost at all(just drive it normal) and you won't have problems with the stk inj. Keeping boost at 9psi should work ok just be easy til you can log it...
