My91TalonTSi
- 115
- 1
- Jun 5, 2004
Freehold,
New Jersey
Today, while doing research on AFPR installs, I found a great thread about fuel injector and fuel pump sizing based on horsepower goals. Steve (a DSM Wiseman) posted some formulas to figure this out. His post is close to the bottom of the thread. Here is the link:
http://dsmtuners.com/forums/showthread.php?t=211590&highlight=installing+afpr
Based on his forumlas, using an 85% max IDC, a .65 BSFC, and my goal of 375hp I figured that I need a 752.76cc injector. So let's say 750cc's to make it easier.
As for the fuel pump, I calculated that I need one that flows 183.6LPH. This figure is based on me using 750cc injectors and an added 20% LPH as a saftey margin. Basically, it sounds like a Walbro 190 will fit my needs.
My questions are: are the forumlas posted by Steve accurate (no offense Steve)? And if so, are my calculations correct?
My starting goal of 375hp is just that, a starting goal. In the future, once my goal is met, I may try to push higher. What I would like to do is is build a set up that will max out a 190lph fuel pump because it will eliminate me having to purchase and tune an AFPR. I am a novice tuner and feel that adding an AFPR would be one more thing that could make the tuning process harder. Do this sound rational?
Thanks in advance for the help.
