injector and fuel pump help with nt dsm
dsmman91
192
May 23, 2011
Tricites, Washington
ok i have a 91 laser nt and i was wondering what i should do to upgrade my nt laser so i can have more fuel for more power be cause i just put a full exhaust and put on a kn intake on my car and i have a few other mods on my car and would like any help
You won't need to spend money on fuel upgrades untill you do forced induction. I have intake, exhaust and ignition and cams and I never get lean except on decel when the ecu cuts fuel. Plain and simple na won't ever really need a better fuel system unless you increase displacment and maybe not even then if your not running high rpm.
(My tsi awd is non turbo by the way)
Adding more fuel will just make your car run richer, which will give you less power, unless you have a way to add more air (which is the great thing about a turbo because that is what it does). You want to maintain a proper Air/Fuel Ratio, which you can't do if you just add more fuel.
