josh408
- 1,763
- 149
- Jan 29, 2011
Fairfield,
California
Does anyone know how to install an ingersol boost solenoid without cutting the harness?
You can use male spade connectors, secure and use heat shrink tubing so they dont arc out on each other. Polarity does not matter.
I would just stick to a home depot MBC for $20-$30.
I had a home depot mbc but already bought the ingersol BCS. I'm trying to regulate boost through link v3.
Those spade connectors will just lock in place?
You still run an MBC, Ted?
I love ECU Boost w/ the IR solenoid. Holds boost so much better than any MBC i've had and you can ramp it in however quickly you like.
Starting to consider just cutting the harness now.
Just splice into the harness. It take 2 minutes and can be reversed. Don't complicate a simple install.
Ted, come on man! Dial in takes no time at all. ...and i don't have to turn anything to turn it up. ..just a couple clicks. haha! But if it works for you, keep on doin' it!
