Boost control solenoid? wasgate solenoid? question
91awd-t
Apr 25, 2012
Hebron, Indiana
Umm well I've been reading alot of post about 8psi and boost control solenoids and so fourth and I'm also stuck at 8psi and I'm trying to find a stock boost control solenoid or wastegate solenoid same thing right? I've been looking on line every where can't seem to find anything I don't want a mbcs because well I'm stock n I'm trying to pass emissions so getting all the vac lines lined up and everything so basically can anyone tell me where to get a stock boost solenoid. So that i can sit happy at 10-11 instead of 8psi thanks
Just do away with the bcs and run off wastegate spring pressure.;) Just run a line straight from the turbo outlet elbow to the wastegate actuator and forget about the rest. Take the bcs off and tuck the wire out of sight, then you have nothing to worry about. Boost should be in the 10-12psi range and you should be good to go.:D
I've been looking for a stock one too so my car can pass inspection. All I need to do is have it plugged into the harness. If you find anything let me know please. Thanks!
I agree 100% I've done this exact thing to my friends gst...
