pneumo
- 3,763
- 61
- Oct 19, 2002
Bay Area,
California
Fast with class? What's that? Ha, actually the interior looks exactly the same as last time, except there's a SAFC where the radio/tape player used to be. I made a sheet aluminum panel to mount the SAFC, then painted the panel black so it looks classy.
I just realized I can save another pound by replacing my full face helmet with an open face helmet! Yess!!!!!
jk
Forged rods should be re-sized to match the crank and piston pin, so add that to the cost of forged rods. Most forged rods have slightly tight clearances so you can enlarge them to suit your needs.
Removing the auto seatbelts was easy, there's just a lot of stuff to remove, like the panels just behind the door, trim along the door frame, and the whole center console. All the panels can go back in. There's also a little computer box behind the drivers side panel that controls that annoying beeping sound you hear whenever you leave the key in/ door open. I took it out and NO MORE DAMM IDIOTIC BEEPING!! It's so nice. I'm using a manual belt I got from JCWhitney. It only cost $34.99. part # GM176097 for gray, #GM176094 for black. They have other colors if you want some bling. There are plenty of mounting points and spare bolts to mount the new belts. It weighs 2.2 pounds. It does not have a tensioner, so I've been adjusting it everytime I get in the car- kinda annoying. I REALLY like how I can crank down the adjuster to lock myself into the seat. Cornering is awesome this way. It feels great to take a hard corner without having to brace myself with my arms, legs, and clenched butt cheeks.
jkForged rods should be re-sized to match the crank and piston pin, so add that to the cost of forged rods. Most forged rods have slightly tight clearances so you can enlarge them to suit your needs.
and I have too much work in the shop to find time to put those things in by next wednesday...
and was thinking 707 whp on 31 psi with a crappy tune, thats basically what I want out of this little beast. Say a good tune adds 20-30 hp, and the drivetrain loss from awd vs fwd cancels that out, thats a clean 700 whp and that turbo is far from done at that psi. I have been looking at the fp 3575, and was thinking that with a 100-150 shot would get me into the 700's, but being able to get 700 out of 31 psi and no nos would be sick. Anyone know of a good cast manifold for that turbo? Ill probably just go tubular, but I remember seeing picks of shep's 9 second set up using a cast t3 style manifold, by turbonetics if I remeber correctly, so obviously tubulars don't flow that much more than casts. Also, see the sbr turbo compro where they put a tubular manifold on the evoIII
(just put that there 'cause I like the smiley, otherwise I don't have anything constructive to comment on that)
With his gatorade bottle of methanol... i mean "water".
