I'm running realy lean Need help !!!!
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
2day i drove my car around the block,and my wideband O2 sensor how me that I'm running really lean, the car loosing power and idles really horrible i don't know what the hell is wrong with it
need help from you guys,thanks alot
im almost for sure now. you need the base idle procedure im going to be doing it to my car within the next week hopfully so ill send you the directions when i get them from my uncle and ill bet you that will help
what if i go to the DSM shop (Turbotrix),how much they will charge me to fix my timing,because i really don't want to mess with it by my own, it seems very difficult to do that
BTW i think it has nothing to do with the base idle procedure,because my car is not boosting as good as it should be,running 17 PSI right now and it feels like im going 5-7 PSI
today i checked my timing marks on the cam gears.
every time when i start my engine,the cam gear teeths are in different place,here is the pictures:
attachment.php
attachment.php
attachment.php
is it suposed to be like that or is something wrong??
i start my engine three times in a row and posted those resylts og my timing
The cam gears are going to change position because they spin when the engine is running. First, find top dead center on the engine(line the notch in the harmonic balancer to the 0 on the plastic timing cover) and then follow this diagram for checking the timing marks on the cam gears.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
