1G help with lean running
alexs' tsi
May 3, 2015
Regina, SK, Canada
i have ecmlink v3 and took a log for you guys to look at, basically the car leans out hard, like 18/1, (using lc1) the plugs look lean and the car runs like shit too when the wideband reads lean,
sooo a background,,,
one morning the car ran a little lean on cold startup but went to normal after i started driving, but i did notice that any sudden throttle pos changes made the car lean a little hitting 16:1 just long enough for you to see then going back to normal afr at the new throttle position, now i cant barely get it to run by itself, runs way to lean to let it idle and revving it still reads lean, like 17;1-18;1, the car is definetly leaning as i have no exhaust leaks before the wideband so it is accurate, any help please i am stumped ??
looks like a BLT is in order, some hose fell off somewhere or you have a rupture in a hose, crack in the piping, something to that effect. I think your exhaust is fine, but there's an opening for air to get in somewhere along the intake tract.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
