im having electrical problems on 2nd gen need help
gearhead37683
57
Aug 4, 2009
mtn city, Tennessee
hey guys my friend has a 2nd gen talon awd,and he recently bought an engine for it and after he put it in it wouldnt run, and he took it to the shop where they got it running but it will only run if you unhook the battery and then start it, but after u turn it off it will not start again until you unhook the battery and then hook it back up again. we changed ecm's on it hoping that would help but it does the same thing, the shop said it was a bad wiring harness but it ran fine until the engine blew up, does anyone know where to start with this thing, or what might be wrong? thanks for the help
MAYBE you should change the battery. That would def be the first place I would start. Next, starter, then the alternator and so on. Plenty of no start threads. DO NOT BUMP your own thread. Next SEARCH.
