Road-Rocket
- 201
- 0
- Mar 8, 2003
Escondido,
California
I decided to do an oil change today since the car needed it. It is my fist time doing it and I f***ed up. Instead of draining the oil from the engine, I ended up draining the oil from the transmition. Its an auto. On top of that, not only did I drain the trans fluid, I also put another 3 quarts of oil in the engine, which I thought I drained. No wonder my dipstick was showing oil level way above normal. Here's the worst part, I took the car for a drive with all that oil in the engine and no fluid in the transmition. I drove it for 5 minutes around the block. I noticed that the car tried to stall everytime I shifted from P or N to D. That's when I knew the I did something wrong. I took a look below the engine and that's when I realized WTF that I f***ed up.
Now, you can go ahead and start laughing at me.
I deserve it. But as soon as you're done, I'd like to know the following. Is it possible that I damaged my transmition by running it for 5 mins without fluid? I didn't hear anything break, just noticed the car wanted to stall when shifting from N to D. How bad is it to drive your car with 3 quarts of oil more than the normal? I'm going to drain the oil and do it again. The right way of course
But did I cause any type of damage to the engine by putting so much oil in it? And last, I'll be doing a search on this one but, before refilling the trans fluid, do I need to change the filter as well? Or can I go ahead and refill the trans fluid just like that? Any info will be greatly appreciated.
This makes me sick to my stomach.
It is never good to run a car without tranny fluid for any amount of time, I would fill it back up and not worry about it unless you start hearing noises or something. As for the oil hopefully you still changed it when you got home.
! Hopefully I dont make that mistake i just put mine back in.
