supermr2boy
- 0
- Oct 28, 2012
edmonton,
AB, Canada
If you have crankwalk..will it stall only in neutral with clutch depressed? Or will it also stall in gear? My car has a problem that when I first start the car, idle is at about 1300 and when I depress the clutch in neutral with the car just sitting, the rpms go down by 200. When the car warms up, and the clutch is fully disengaged, the rpms drop enough to stall the car. If the car stalls in succession due to this, the car gets kind of hard to start back up and needs to rest a bit before starting again. This only happens in neutral and not in gear. Car runs perfectly fine other then this. Is this crankwalk? The car is a 1991 Toyota mr2 turbo. Feedback is greatly appreciated, thanks!
but best of luck to you
