Car wont rev past 1000-1500 (idle) will stall out if you give it any gas and wont rev
silver bullit
2,312
9
Jan 27, 2006
martinsburg, West Virginia
Car wont rev past 1000-1500 (idle) will stall out if you give it any gas and is was 10 minutes before and all day yesterday it would not rev past 5500 almost like a stuterbox launch but it would rev higher than 5500 in all the gears including neutral. Please help thanks.
* Ok it seems the plug for the throttle body came off due to me not having the metal clips, i bought it this way and i knew about dsm's and why i need them.
However i still cant rev past 4500-5500, is this due to the honeycombs are out of the maf?
No it was the ecu, since it was a eprom one i had a chip made for it but the chip was bad and had voids and the epoxy was peeling on the chip.
It was all the ecu fault, a different maf helped so i switched one out but not much better till i swapped the ecu
So my 91 wont start unless i unplug fuel pump and turn it over then plug it in and it will start. When i give it gas it wont rev just idle or stall. Then it wont start and it reeks of unburned fuel. Ive fixed all bad wires, checked cts ecu fuel filter and fpr. I even took my evo 560's and put stock 450 injectors. It fired up then stalled and wont start. Help guys
i have 2 2g mafs and i tried both they are good. I pulled ecu out and put in a eprom ecu. They both look good not leaking. How can i tell?
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
  • For sale 4G63 MHI 20G Turbo
    MHI 20G Turbo $500 + shipping & paypal fees* setup for external waste gate * just serviced by...
  • For sale 2g 2G Manual Shifter Cables
    2G Manual Shifter Cables $90 + shipping & paypal feesYou must be registered to see element.You...
