- Thread starter
- #26
4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
Thanks so much for helping me out. I'll report back once I get the dowels out. Hopefully I can achieve .003 or less at the block.
I must say that your 90 degree trick worked out great. The pistons are all in the same spot more or less.
Well I have some tough decisions to make. I got one of these:
16" x 24" Steel Square
and one of these:
Feeler Gauge - 32 Piece, SAE/Metric
I am getting .006 in some places on the block if I put the T-Square on it's edge.
When I tip the t square edge on it's side, I can't get more than .003....not sure if that is cheating.
I would try the extension, but I don't have a piece of glass handy. Maybe I could put it against a mirror to be sure.
One of the review on the feeler gauge says that it is not accurate. You did say to get a decent set of feeler gauges.
It might be worth going to NAPA to get this figured out. If I need to get this block decked it is part out time. My GVR4 needs parts.
***Well I used my glass front door to my house against the t- square and noticed that the t square easily allowed .003 at the same point where my block is "warped".
Let this be a warning to anyone who tries to use that particular T-Square for this purpose.
****Got myself a piece of glass and at no point on the block did it exceed .003....YAAAAY!
I pulled your pics up on your PB account, and zoomed in.
Yes where the fire ring distorted is where the gasket failed.
Like a head the flatter the better, so you want .003 or less warp in the block. If you find .003 of warp in the block, it should come out and be decked.
This link shows how to remove the head alignment dowels.
http://www.dsmtuners.com/forums/new...r-how-clean-block-deck-pistons-installed.html
If you use this procedure, one thing I left out was plugging the oil feed hole.
and one of these:
