Blown Head Gasket :(
Mike1992
3,338
26
Jul 19, 2003
Springfield, Missouri
I posted up a few days ago how I was having crazy loud lifter tick noise, or so I thought, but I think I found the source of the loud ticking noise. Car has been running really well, but this lifter tick noise gradually got louder over a 2 day span so I decided to investigate. Tore the topend apart to find nothing unusual. Came out this morning to find a puddle of coolant under the block. Couldn,t find the leak so I rented a coolant pressure tester to find two small leaks on the back of the block where the head and block meet, pointing towards a HG failure. Pulled the head to find this.....
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed015.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed014.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed013.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed012.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed011.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed010.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed009.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed008.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed007.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed006.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed005.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed004.jpg
http://i51.photobucket.com/albums/f360/Lasercamel/Blowed003.jpg
I am sure that it is just wear and tear, but over all its not awful you can clean the pistons and such, I see you run an hx35 at 28 psi, that could cause it eventually.
This was an OEM composite head gasket with std arp's torqued to 90lbs. This is my other car sporting a built 2.0 Ross/Eagle BC 280's and a HX-40 Turbo. This engine had less than 500 miles on it.
