Idling Issues.
GSX 95 eclipse
55
Apr 1, 2011
spokane, Washington
I had just recently pulled my engine out of my 98 GSX and put it in my 95 GSX. For some reason my car is idling really bad and sometimes wont even stay on. I think it is just because i am boost leaking but iam not sure.
Please reply with any ideas on how to fix this.:banghead:
And you shouldn't have even made the thread until AFTER the boost leak test.
And even then you shouldn't have made the thread until after SEARCHING.
Any check engine lights on?
Also, boost leaks generally do not translate into an idle problem unless you have a charge pipe completely blown off....at which point you won't be able to make any boost at all- as dboyle23 outlined above. You're more likely to have a vacuum leak causing an idle issue than a boost leak, so check any of the vacuum lines going from the intake manifold to their various locations.
