Idling issue/running rich with video
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
99 GSX 6 bolt. T28, wally 255 rewired, Tial BOV atmospheric w/ maf-T..
(This is all while idling or reving in neutral) Usually, I get a little black smoke from the tailpipe and sometimes ill get a loud backfire at higher RPMs. Also when I rev, and my RPMs drop it will almost die and start running lean and in general run bad for 5 seconds all while the lights flicker then go to normalish, in the video you can also hear the pumps tone change with the power fluctuations/rough idle. Last half of video is of the tail end, to see the smoke (and a little awd action :D ).
During the video its about 7° outside, and the engine temp was roughly 140F. What do you guys think? Im stumped.
https://www.youtube.com/watch?v=5BaH8XsfhVU&feature=youtube_gdata_player
No I am using an innovate wideband, the video shows that. And I might have some small boost leaks but at idle it really shouldn't matter, right? Especially if my maf is right before the throttle body.
I attempted a boost leak test earlier but during the test at about 4psi my soapy water was freezing (7° outside) . Just in the 4psi I found two of my couplers were loose both fixed. Also, my biss screw was also leaking some not fixed (Will use silicone). When it gets warmer I Will attempt another boost leak test up to 15 psi
A leaky BISS screw would make your idle go up not down. Anything leaking after the TB butterfly will make your idle go up. ISC may not be working properly.
