Idler pulley
SlowChild3
545
9
Aug 19, 2005
Dayton, Ohio
Is this ok to use? Just use a shorter bolt?
They look identical in size beside the center.
Yes, that one will be fine. You'll want to use a 22 mm bolt rather than the one you have; it's part number MF241281 if you want the OEM one.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
