420A Idle Surging
Skyline-Tweak
64
Nov 11, 2012
Kunkletown, Pennsylvania
420A. So after I pulled the engine and transmission, put it all back together and started to have idling issues. No code at first. So I started the car and pulled the IAC Motor plug. Ran the same. Then plugged it back in and it threw a code. P0505. Took the IAC Motor out. Tested it. It's good. Harness is shot. Tested with test light. Nothing frayed or melted. Anyone have a 95 420A ECU pin out to test for shorts? If no shorts come up any ideas on what it could be? Need the car for work tomorrow. Thank you in advance.
Okay, so I continued to mess with the IAC. I reinstalled the IAC since the motor tested fine. Manual said 38-52 Ohms. It's at 51. Tested the connector and it wasnt getting power through any of the 4 prongs. Tried to follow some wires and got lost. Looked for a pinout and can't find one. I was planning on testing it through the wires to the closest point to the ecu to see if there's a short. Now I'm wondering, if I follow the wires and if there's no power running out of the computer, then what do I do? I was told unplugging a computer from its harness resets the computer. Would that be bad?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
