Idle surge problem need your guys help
ghettorapboy7
Feb 16, 2009
Toledo, Ohio
Hey guys I have a idle surge question (ya i kno). Ok first things first when I try and start my car it wont start unless I cycle the key like 15 times after that it will start however the idle surge is so bad on startup that it will die if I dont keep giving it gas. But when the car is warmed up u can start it up with ease and the idle surge isnt as bad it goes up and down like 100rpm or something like that not to sure. I have already: took the throtle body off cleaned it off, put on a new tps sensor, rehooked up the egr valve and coolant temp sensor vaccum because they were reouted for some reason, put on a new isc, fixed a boost leak with better gaskets (however i have not checked for actual boost leaks), exhaust manifold had a crack in it replaced that with a header, and the timing has been check and everything is good. Ok now the bad: I use to have an afc in it and i took that out because when a friend pulled on it it shut off, ill have pure tuning dick with that later, I am running a 2g maf sensor and have no idea if it even works, the injectors are stock, I am running rich, the fake ass hks ssq bov is shot and I will be getting a new one just dont have the funds for that right now. I think that is everything I can think of but I may have forgot somethings but I need you guyes expertise! Please help me!
I have had a lot of work done at Pure Tuning to my car and the guys are very good. I think you have bitten off more then you can chew.
I recommend that yo take it to them and let them help you get things in running order.
