idle problem with revs
daltah
516
Sep 27, 2002
phoenix, Arizona
When ever I try to hold my rpms at 2k or 2.5k it will bounce up and down it will not stay there. It either want to keep going up or will bounce up and down. Is this a sensor or what?It only does it in neutral or when the clutch is in. I have a 95tsi awd.
steve said:
You might want to do some research on idle surge. Sounds like you have a case of it.
When I idle its fine. It only does it when I rev the engine and try to keep it at a certain rpm.
Still your getting a surge. Search Idle Surge and you will find what you need. There are like 10 different things that cause that. Dirty throttlebody, to tight of throttle cable, bad ics, bad tps, ect. Just search.
