idle problem and grinding when i shift
92talon1992
Dec 2, 2011
Eugene, Oregon
I have a 92 talon body with a 92 eclipse 2.0l motor, and on the start up it will idle up and down going from about 1.5k to 2.5k while in neutral or coasting to a stop. Once it warms up a little bit it ends up running fine, but i figured it was still a problem that needed dealt with. Part 2 of this, when i shift into 3rd or 4th it grinds it doesn't happen all the time(I try to be really careful when shifting) but it always happens when i gear down so i try no to gear down. I ended up getting a new tranny but stayed the same, I thought the possibility of 2 bad trannys in a row that did the same this wasn't to great. Any suggestions on the idle or shifting problems?
Idle surge for the first one, and you most likely need to adjust your linkage for the second.
