jayb903
- 99
- 4
- Jul 19, 2007
Fayetteville,
North Carolina
I'm trying to track down this udle misfire. So far I have ruled out cas, plug, wires, coil, pt, mas, and I just did the egr blocked off. So I'm wondering should I just go ahead and do the 1g cas swap as to get rid of the crank sensor? Because I'm getting close to solving this problem and I'm wondering if this is a better option than buying a 2g cps.
But on the other hand I changed my plugs to the "NGK BPR6EKN" the misfire code(p0300) never came up, yet it sounded worse than when I had my NGK BPR7ES in. But when I put the BPR7ES in, the misfire code came up again. In both cases the misfire is there.
