idle/dying problem
eagelfan92
92
Oct 28, 2011
coloradosprings, Colorado
The problem seems to be fixed as long as i keep it out of boost it will behave. if i have it in any positive pressure and push in the clutch it will stutter and die some times but other than that its fine. going to check for a major boost/vac leak and see what i can find.
That'll happen with a huge boost leak. My turbo to manifold bolt used to walk itself out and it would do exactly what you're describing.
