dying problem?
eclips3_xs
79
Jul 23, 2008
Burbank, Illinois
ok here we go again when i drive the gar for a bit and later on i punch it not all the way in like 5, 6000rpm w/e the car dies out it only happens if i don't switch the gears when i do im fine what could it be.
Thats one long, sorta confusing sentence. Are you saying you can't go above 5500ish RPMS without it cutting out? Have you checked for boost leaks lately?
You shouldnt fix most of them. You should fix ALL of them.
Boost Leaks will tear you apart. Trust me I know. Just jump in the engine bay, yell "THE IS SPARTAAAAAAAAAAAAAA!!!!" and go to town checking and fixing and checking and fixing until you check and nothing needs fixing.
yeh men that sounds great. It gots to run smoothly no jumping and cutting off power right.
