FadedBlue
- 51
- 0
- Feb 24, 2013
Mineral Ridge,
Ohio
I have been working on my idle issues for the past hour. I paid more attention to the idle today and found out that its been idling around 700-800rpm with no load on the motor when I turned on the AC it dropped to 500. I then shut the car off and unplugged the Idle Air Control harness started the car up adjust the idle screw and the idle went up to 1200rpm I then shut the car down and plugged the harness back in started the car again and it was idling at 1000 with no load on the motor I turned the AC on and it again dropped to 500rpms. I did some research and what I found was this Mitsubishi Repair: Low idle and stalling, mitsubishi eclipse, electrical load the car does not stall but comes close to it so I believe this is my issue but I am unsure as to whether I need to replace the harness or the idle air control valve could someone explain this to me so I know what to do to fix my issue
