at idle motor under load? runs like $#¡+
faulkner
191
Apr 22, 2013
spring lake, Michigan
I have a 95 gst. Just finished my 6-bolt swap with 7-bolt head. New plugs
And wires. Compression is good. But when I take off it hesitates a little bit
And accelerates like a snail. Builds boots just goes no where like it should.
And I hooked up my scanner and it says load:20 at idle??? Than when I
Push the gas it goes down? Not sure what's going on or what. Can any one
Show me the proven proper spark plug wire order also thank you.
swapplugwires [ECMTuning - wiki]
Spark plug wiring...
After looking at your logs, at WOT I noticed you only showing 99% throttle. Other than that IDK what going on? Have you changed your DA tables at all? Your MAFRaw only shows 14 and some Hz at about 12psi boost, that sound correct?
car will idle at 7-800. sometimes after a drive it wont idle inder 1200.
heres the readings at 3000 rpms in 3rd gear
