StavRedline
- 0
- Dec 3, 2008
Cheltenham,
Europe
Hopefully, this will be a 2way thread- You can help me by confirming what it is exactly, I can help you by showing you what part numbers are on it all so you know what to order
I'd normally post this in the Holset part numbers thread, but I'm not enough of a post-whore to be allowed in yet it seems
The turbo is a brand new Holset, HX52 i think, with a 16cm exhaust side, external gate ex' housing, T4 flange with the usual slightly different to Garrett bolt pattern, V-band clamps holding the housings on, and a V-band exhaust outlet.
Right then, detailed pics...
Compressor... HX52? HX55? Anyone know?
These numbers were drawn on the housing...
Compressor wheel, 7 blade, looks cast to me, 65mm inducer, 98mm exducer (if my calipers are accurate!)
Number printed on the compressor plate...
Another number on the compressor housing backplate...
Turbine...
A 16cm one...
Some part numbers...
Also had this part number drawn on turbine housing...
12 blade turbine wheel...
84mm inducer, 70mm exducer...
Hope this helps people, and hopefully someone can give me info on it too!
Going by Garrett GT specs, its somewhere between a GT4088 and GT4094, but with an exducer even bigger, almost GT4202 size.
Going by Garrett terms youd say the turbo is good for 750bhp, just more efficient at high boost pressures.
BUT people seem to say Holsets do far more power than Garretts for the wheel size, so I'll let you Holset experts say what this turbo really can push out...
Turbine...
A 16cm one...
