iac swap
stace
86
16
May 27, 2008
Belleville, ON, Canada
Can I swap a 2g IAC into a 90'?
Mine is bad and all I got sitting around here is a couple 2g IAC's and a non turbo 1g IAC. They all seem to look the same and will connect into the same connector but they point in differant directions on the TB and are differant colours.
Plus the 90 has a pigtail, but the same 6pin connector.
I have a 1990 IAC and I'm in need of a 91-94 IAC. I will trade you if your interested. My OEM 1990 IAC is almost brand new and I just recently tested it out to make shure it was all good. every test and I even installed it on a friends 1990 gsx to be shure it works great.
Im offering this so you can have an origional part for your car that it requires. I think your BISS was messed with on your TB to make the IAC burn out. Messing with the BISS is almost the number one cause of the IAC's getting burned out. So make shure its all good when you put the new IAC in there or the new one will burn out like your old one did.
