I think my wiring jacked
V8Killer25
368
Oct 22, 2011
Little Rock, Arkansas
here is my problem guys the water senser is u plug to keep the fans running to keep the block cool, but i runs like shit. when i plug it up the fans dont run the car runs better but it gets hot super fast. Any answers would help????
All of my problems are with the water sensor being plugged up or not. Like I said when it is plugged up the fan in front dont run at all. The car it self over all runs better but it over heats over 200 degrees and smokes. Now when the water sensor is unplugged both fans run it stays cool but it runs like shit. sorry if i made it confusing. I think the wiring needs to be redone.
If you've replaced the sensor then start tracing back the specific wiring that is responsible for the operation. You will most likely find some break, crack or separation of the link near the plug itself as this area is most susceptible to heat damage. You may also want to replace your thermostat if you haven't already replaced it.
Good Luck.
