SonySlave
- 967
- 75
- Jun 24, 2004
Pasadena,
Maryland
Well I just replaced my 98 Eclipse RS with a 95 Talon TSi AWD. The car has 66,xxx miles on it, dealer I bought it from said the thing had a blown turbo. So I found a 14b and was going to replace it... Turbo isn't blown at all...
When I start driving, everything is fine, tranny shifts smooth. Then as soon as I hit about 3k rpms, I start to hear a sound coming from the lower engine area. It sounds almost like a really bad rattling or like a huge hole in the exhaust. Then I let off the gas and it dies down. Doesn't matter what gear I'm in either. 5th gear crusing on the freeway at 60-65 at 3k rpms+ the sound is constant. And I feel a thumping coming from under the car right below me at the same time (kind of thumping like if your wheels were off balance).
Had a mechanic friend that used to work at Mitsu look at it and he believes that the input/output shaft bearings are bad in the transfer case. Maybe? I'm still learning the 4G63 and especially the AWD. I read about the transfer case recall, could probably look into that I think.
Any info would help!
....sounds very familiar!
